Configures VLAN ports to stop forwarding the traffic from all multicast groups, unless MLD joins have been received on the port.
vlan_name | Specifies a VLAN name. |
port_list | Specifies one or more ports or slots and ports. On a SummitStack, it can be a list of slots and ports. On a standalone switch, it can be one or more port numbers. May be in the form 1, 2, 3-5, 2:5, 2:6-2:8. |
None.
Use this command to remove the configuration that forwards all multicast groups to the specified VLAN ports.
The following example removes a static MLD entry so all multicast groups are not forwarded to VLAN marketing on ports 2:1-2:4, unless an MLD join is received on the port:
configure mld snooping marketing ports 2:1-2:4 delete static router
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
